I want to change out my pedals on the Lancer ES CVT i hate the stock ones. Can some tell me if its pretty easy to do. I am thinking about these Sparco ones http://www.sparcousa.com/ptuning_pedals.asp?id=356
It's rather simple. Any aftermarket pedal you purchase, is just an overlay for your current pedal. They normally come with a mounting bracket and instructions to do it. Took me about 10 minutes to install mine.
I see i guess i was just over thinking it a lot simpler than i thought. Now i just have decide on which ones to with. Im trying to keep everything in the car to specific theme so silver and black might be the way to go. Should be wary of the length of the gas pedal someone told me make sure its not long and that it will fit?
if its too long,then i would make them be flush even with the original gas pedal from the bottom up,so you know that your getting everything out of your lancer!
Cool thanks for the advice i spent the weekend looking around i managed to settle on 2 or 3 and i will chose from those.
