Black Tail lights from Mitsubishi
Discussion in '8G Lancer - Customization' started by BaD2RaSS, Sep 26, 2008.
  1. BaD2RaSS
    BaD2RaSS Well-Known Member
    Here is a little step by step that was recommended when I put these on.
    These are the tools you will need A 10mm ratchet or box wrench philips screw driver and some trim tools.
    Remove all of these clips on the trunk insulator pad by popping them up with a small trim tool or a small flat blade screw driver
    loosen these bolts two per lamp on the trunk
    Pry here first slowly with trim tool
    pry here second with trim tool. Then remove all connectors. repeat for other side
    Just be warned when removing lamps they will make loud not good sounds but it is just the retaining nipple being released from the grommet.
    I forgot to take pics of the lamp removal on the body itself however it is simple just loosen the two screws holding it in place and then pull the light out it may help to pry with the trim tool against the leading corner of the lamp.
    Once you remove the lamp There is a grommet that goes into the car remove it and disconnect the lamp.
    Be sure to connect new lamp.
    When installing new lamps apply some white lithium grease or di-electric grease to the grommets this will make future removal of the lamps easier, press gingerly on the edges of the lamp not in the centers because that could cause damage to the lamp.
    If you have any further questions let me know.
    If you don't think you want to chance it let the dealer install them they shouldn't charge more than $75 for labor to install them. or 1 hour labor.
    By the way this only takes about 20 min
    Kyle
  2. BaD2RaSS
    My camera died at this point so i will post some better shots tomorrow in the sunlight.
    Kyle
  3. nickbutterz
    nickbutterz Well-Known Member
    DAMMM SONN!! sickk.. where did you get them from your local dealer? or japan? they look sickk thoo. how much?
  4. AuToMaTiC
    AuToMaTiC Member
    Beautifully done!
  5. papi2dmamis
    papi2dmamis Well-Known Member
    That's a nice look. :)
  6. XxLaNcErGTSxX
    Mine come in next week. I was number 3 on the over on evom
  7. Evo8cfb
    Evo8cfb Member
    looks pretty good
  8. malblast
    malblast Active Member
    awsome cant wait to get them
  9. BaD2RaSS
    Yeah dealers can get them they are hard to get right now though. I am the dealer :lol:
    Kyle
  10. vik2rius
    vik2rius Well-Known Member
    looks like im not the only one anymore...
    looks 10x cooler, dont you think? lol...
    +1
    yeah i know its a little red...
    well, i can say u'rs are only 11x cooler, just 1 higher than mine since theyre only home-made... :D
  11. BaD2RaSS
    vik2rius that looks good man I wanted to tint mine still might tint the black ones i think it would look awesome
    Kyle
  12. vik2rius
    thanks man, im sorry to say that i didnt tint my tails...i actually cut them open and paint the inside black...and to give it more darkness, i painted the edges as well to make them look more blackout...thus from a far they really look blacked out...
    same goes to yours...looking good...
  13. BaD2RaSS
    it looks good either way
  14. orin12
    orin12 Well-Known Member
    where can i get the chrome lettering that spells out lancer on that WW GTS ive been looking for a while and yet to find it
  15. RALLIART
    badgeyourride.com
  16. RALLIART
    kyle awesome write up, tail lamps look sick as hell!!! let me know when they will be available to order. remember what we talked about :D
  17. batzr
    batzr Member
    that's the look bro!
  18. BaD2RaSS
    No problem man
    Kyle
  19. LuvMyLancer
    LuvMyLancer Well-Known Member
    I see you beat me to the Autobot symbol hahaha cept I was gonna take the Mitsu emblems off completely and put the Autobot one there instead :p
  20. Keeeent
    Keeeent Well-Known Member
    Where can I get that clip thing for my trunk? I just took off my spoiler and that would go great with my trunk.
