Another brake question...
Discussion in '7G Lancer and older - Performance' started by Ron Thompson, Jul 19, 2009.
  1. Ron Thompson
    Ron Thompson Member
    Are there any mitsu cars that have two or tree piston front disk brakes that will be compatible with an 02 lancer oz?
  2. lancer2quick
    The Brembo setup from an VIII or IX will work, but you have to swap the hubs, rotors, brakelines,etc. The drawback from that..you lose your ABS, and you have to run at least 18 inch wheels..unless you get the Evo wheels also.
  3. Ron Thompson
    Ron Thompson Member
    Well the one i have doesn't have ABS unfortunatly so it doesn't matter for me. Are there any others out there maybe ones that fit 17" wheels?
  4. Guest
    Ralliart swap is more ideal.
    Check the other thread I posted which has all the parts you need.
