Hopefully tmrw or this week i wil be installing my alrm/remote start/everything there is possible its the python 990 2 way remote with LCD
Nice! When I decide which Lancer I'm getting, I'm probably going to go with a Compustar remote starter/alarm combo. I have one on my Civic and it's great
Can you wire the alarm up to the smartkey entry? I'm too used to not taking my keys out of my pocket hah
sure am.. and not because of the brand really.. but since I installed the 5002, I just havent been happy with it at all.... the reception on the 2 way pager sux..probably just a bad antenna but my sponsor is an auto page dealer so I really liked all the things that this alarm will do.. however.. not sure how ima hook up the remote start to my Manual... specs: 2-Way O.L.E.D. Remote Start w/ 6 Channel Alarm RS-1000 OLED NEW 900MHz, Six-Channel Alarm System with Remote Car Starter and Two Way FM/FM Paging O.L.E.D. Remote Transmitter STANDARD COMPONENTS: · 6 Channel Alarm and Remote Car Starter with 5 on-board MICRO relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable. · New On-board Serial Port for AP Data Link Data Bus Integration · Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 900 megahertz. Unit will transmit and receive up to 1 MILE. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer. · New MANCHESTER CODE encoder. · NEW STYLE Two-way, window mount SUPER EXTENDED RANGE transceiver antenna module. · One 5-button extended range FM, standard 900-megahertz SLIDE COVER remote transmitter. · SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity. · Discrete Temperature Sensor that communicates in-car temperature with LCD remote. · Window-mount Knock Sensor for driver paging. Plug-in super bright mini-BLUE LED and push-type valet/override switch. TWO-WAY O.L.E.D. REMOTE OPERATION: · 5-button configuration with selectable Button Lock to prevent accidental mis-use. · Uses a rechargeable battery via Mini USB type connector w/ wall charger included. · Battery life indicator and power save mode · Full color (O.L.E.D. Organic Light Emitting Diode) with over 100 icons and animation screens. · Optional Two Car Operation with LCD transmitter only · Transmits on FM band and receives on FM band. · 24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius. · Multiple audible confirmation tones as well as vibrator mode for paging. 2-way Transmitter Range Check Indicator ALARM FEATURES: · Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs) · Dedicated function buttons on LCD remote and 4-button standard remote transmitter. · Code learning / Anti-scan receiver with programmable code hopping. · Back-up memory system · Selectable Chirp Confirmation (OEM Style lock only chirp confirmation) · Comfort Feature with OEM systems having key / remote control power window roll-up · Dedicated remote panic and car locator · Passive arming by-pass from the remote · Parking light flash with dual polarity relay on-board · Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote · Starter disable output with relay and socket included · Dome light illuminated entry output · Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock · Additional positive and negative inputs · 500 mA grounded outputs for starter disable and door lock/unlock · Programmable momentary, latched or timer on 3 auxiliary channels. · Programmable manual / passive arming with true last door arming with auto re-arm on · Programmable Single / Double Pulse Unlock (7 new timing adjustments) · Programmable Parking lights (flash or constant) · Programmable Pathway Illumination (on / off) · Programmable voltage sense for delayed dome lights (on / off) · Programmable horn and siren chirp delete · Programmable ignition control lock and unlock · Programmable pulse time for lock and unlock (.9 sec. / 3 sec.) REMOTE CAR STARTER FEATURES: · 5 On-Board Relays: 1. Ignition 1 2. Ignition 2 3. Starter 4. Accessory 5. Parking Light · 3rd Ignition (-) output · Dedicated Second Start wire · Dedicated Ground out when running · GM- Non starter wire timing compatible · Ground when start (-) output · New Turbo Timer feature · 2nd Accessory (-) output · Selectable one or two push Safety Start · Programmable gasoline or diesel with 10, 15, or 20 second Wait-to-Start · Hood pin switch safety input (pin switch included) · Selectable RPM / Voltage Start · RPM / Voltage / Hi-Low level check · Timer control start option · Sensor control output during start · Temporary Stop Feature · Factory Alarm Disarm and Rearm signal output · Programmable factory keyless door locking before and after start · Programmable start status output with shock sensor bypass · 45 second door / dome light bypass after ignition is turned off. · Programmable Ignition 2 (on / off) · Programmable 3 hour timer start · Programmable 1 / 3 hour timer start · Selectable Run Timer (5/10/20/30 minutes) · Selectable Gasoline / diesel Selectable Diesel warm-up time I mean really.. who wouldn want all that.. I got window mods too
