OMG set a goal for yourself http://www.dynolab.net/hp.shtml "Horsepower Results - 1/4 Mile Method Your LancerGTS88 weighs about 2950 pounds and can complete a 1/4 mile in about 14.0 seconds. That means that you've got about 212.48 HP at the wheels, and about 276.23 HP at the flywheel." MY NEW GOAL!!
or something crazy and only in my dreams :lol: "Horsepower Results - 1/4 Mile Method Your LancerGTSL33THAXXOR weighs about 1900 pounds and can complete a 1/4 mile in about 3 seconds. That means that you've got about 13908.41 HP at the wheels, and about 18080.94 HP at the flywheel."
I actually posted "real" numbers and here's what I got: "Your Mitsubishi Lancer GTS 2008 weighs about 3310 pounds and can complete a 1/4 mile in about 16.65 seconds. That means that you've got about 141.73 HP at the wheels, and about 184.25 HP at the flywheel." Doubtful! :?
I hate to desagree with you here but i took the weight out of the manual and here it is Your Mitsubishi Lancer GTS weighs about 4039 pounds and can complete a 1/4 mile in about 19.0 seconds. That means that you've got about 116.39 HP at the wheels, and about 151.30 HP at the flywheel.
Horsepower Results - 1/4 Mile Method Your 2008 lancer weighs about 3000 pounds and can complete a 1/4 mile in about 160 seconds. That means that you've got about 14 HP at the wheels, and about 19 HP at the flywheel. :[
What have you got? A Hummer? The CVT GTS weighs around 3100 lbs, with me inside, add 200 lbs. Hence 3300 lbs.
Where did you get that 160 seconds idea. I wrote 16.65 seconds! :? EDIT: Oh! Sorry! Just reread your post. I first though that you said I ran 160 sec.
I figure that the stickers I put on it give me at least 15 hp. I'm going to go and buy 25lbs of sand this weekend so I can port and polish the head. I figure that would be good for an additional 5mil hp.
Your Mitsubishi Lancer 2008 weighs about 1.5 pounds and can complete a 1/4 mile in about 1 seconds. That means that you've got about 296.47 HP at the wheels, and about 385.41 HP at the flywheel. :wav:
:lol: ...you guys just crack me up... :lol: going back to the topic, that's quite a good hp calculator you found , man...not really impressed with it but cool to mess around with...
well acording to that you should expect around 17.5 seconds 1/4 mile time in stock form which seems believable considering the weight. I'd probably hope it would be between 16 and 17 seconds in real life. Considering the claimed 0-100kmph time ( 0-60mph ) of 9.5 seconds for the manual and 10.5 for the auto. You'd probably get to about 120 kmph if your lucky so about 16 seconds would be fair. But im just throwing around rough numbers, but i think the calculator is a little on the less than optimistic side.
