08 Lancer ECU pinout
Discussion in '8G Lancer - Performance' started by DJ-UniK, Jun 18, 2010.
  1. DJ-UniK
    DJ-UniK Member
    Anyone have the pinout of the ECU connector?? I have the shop manual but can't seem to find a simple pinout of the connector.... Thanks in advance for your help
  2. Sinestra
    Sinestra Well-Known Member
    Contact Ralliart (jake) he should able to help you out.
  3. DJ-UniK
    DJ-UniK Member
    I sent a pm but he dosen't seem to reply...
  4. DJ-UniK
    DJ-UniK Member
    Been 3 weeks... still no reply...
  5. DJ-UniK
    DJ-UniK Member
  6. Jogenmaru
    I should be similar. The 7th gen lancer has the same ecu as the 7th/8th/9th gen evo. It's just a few wires are different. I never figured out which one though. And you would also have to adjust the timing and all for turbo to n/a if you were to use there ecu for some reason.
