Whats up everyone, Okay well I have a 2008 Lancer GTS and it is really getting on my nerves. Out of now where it just tends to bank left and take the wheel right out of my hands. I have been reading about this and its happening to a lot of people. I heard that it was the tires or something and that Mitsu was held responsiable for it. However, I called my dealership telling them with the problem (new york) and they said I will be charged for a wheel alignment test and whatever work needs to be done. Is this right? Has anyone has this done for free if yes send me some post? I would like some proof to show. Thanks a lot --Rob
i had the same problem but since that problem i did get new tires and i also have megan racing coilovers on my ride, i also had a alignment done and i have no problems now ( on a new suspension setup) but on the OEM one i just didnt bother too much, since there was no real solution to the problem with almost everyone having that issue on their GTS. What i did was let some air our of my right front tire, not much, to equal the drag, i solved the problem kinda. That may help you out a bit and calm your nerves down a tad also. :drunken:
Does anyone have their current alignment specs that I could see? I need the following: Left Front Camber Right Front Camber Front Cross Camber Left Front Toe Right Front Toe Front Total Toe Left Front Caster Right Front Caster Front Cross Caster Left Rear Camber Right Rear Camber Rear Cross Camber Right Rear Toe Left Rear Toe Rear Total Toe
