00.30.94 dvd bypass...very easy
Discussion in 'Audio, Security and Electronics' started by pbstud2001, Dec 3, 2008.
  1. pbstud2001
    pbstud2001 Well-Known Member
    i just did this download, it was VERY easy...if you have the 00.30.94 app # then this will work for you
    http://www.deltainfo.ro/manuals/mitsu/outlander/
    1.download from this site
    2.burn files directly to a disk
    3.pop it in the system and a yes or no ??? will pop up, pick yes
    4.upload will begin with a status bar
    5.after that the system will reboot and turn back on...it will ask you if you want to upload again, just eject the disk (its only bc after it turns back on it reads the disk)
    after that your good to go
    source: EJlancer projectlancer.net
  2. EngRWW33
    EngRWW33 Well-Known Member
    Be sure to check the nav version. The newest nav's have version 00.30.99 which there is a patch in the works for.
  3. pbstud2001
    ya...i got my car back in july, finaly found this patch though...just wanted to help anyone that had .94 bc i've seen ALOT of 'do this, do that' threads and this by far the easiest, did everything in under 5 min
  4. almed76
    almed76 New Member
    hi there i have the new version 00.30.99.
    does any one have this new patch yet?
    please help
    thanks
  5. nickbutterz
    nickbutterz Well-Known Member
    why not just ground the wire so it works? idk seems easier
  6. Geaux
    Geaux Well-Known Member
    ^doesn't work on the Lancers, it's not like all the other dvd aftermarket systems.
  7. AeJarrotto
    AeJarrotto Well-Known Member
    yeah it uses the speedo and possibly gps to, plus a gyro. not as easy to bypass.
